Algorithmic design helps you build adaptable design systems driven by logic and data. Rather than creating complex assemblies by building each component individually, you define how they should behave — allowing you to test variations, respond to change, and streamline repetitive tasks. This makes it especially useful for rapid prototyping and iterative design.
Algorithmic design is a structured way of building objects using logic, rules, and parameters. Instead of modeling everything manually, you define how an object should respond when its parameters change. You control the shape, proportions, and behavior of the object, then use editable inputs to adjust those features without redrawing.
This approach works well when you're designing with clear constraints — such as a façade system, a piece of furniture, or any object that needs to adapt based on size, layout, or repetition. It helps you focus on design intent while managing variation through data.
You might also hear this called:
Each term refers to the same idea: using structured logic to generate geometry that responds to change.
Algorithmic design techniques support a different way of thinking; it’s less about the final form and more about how a design responds to inputs. Core concepts of algorithmic design include:
Algorithmic design gives you a structured way to manage variation, repetition, and design changes. Building logic into your models allows you to create systems that adapt instead of relying on constant manual updates. Algorithmic design techniques provide several benefits:
Whether you're designing a modular façade, a configurable furniture line, or a layout that responds to varying site conditions, algorithmic design gives you a way to manage change efficiently while staying aligned with your original intent.
In Vectorworks software, algorithmic design is powered by Marionette—our built-in visual scripting tool that gives you complete control over how objects behave. You can automate tasks, create fully parametric custom objects, and quickly explore design layouts.
With Marionette, you can script actions that would otherwise take hours to do manually. For example:
Landscape Example: When importing a site survey, tree locations may come in as simple geometry with text labels. Marionette can associate that text with the nearby geometry, convert the geometry into Existing Tree objects, and apply the text label to the relevant Existing Tree parameter. What would take hours manually can be done in one automated step.
Architecture Example: When creating a new file, the generation of story and level heights can be automated by running a single network.
Marionette also lets you build your own smart objects—designed to your specifications and editable through the Object Info palette (OIP). These are ideal for discrete objects or systems that need flexibility across a project or client base.
Some examples:
You define how your custom object works, then reuse it with different inputs in different projects.
Marionette makes it easy to randomize object placement within a space—helping you generate more organic, less repetitive arrangements. Rather than placing each object manually, you can define a set of rules to create varied, logic-driven distributions.
This is especially useful when designing:
With Marionette, you can build scripts that control density, rotation, spacing, and more — giving your designs a natural look without the manual work. It is a powerful tool for balancing control with creative variation.
Marionette supports fast layout changes by allowing you to generate multiple design variations. It gives you a quick way to lay out random arrays of objects in a space; like plants in a garden bed, people in a plaza, or tiles in a random pattern. You can generate a handful of options quickly, then choose the best fit — without rebuilding each object within each layout manually.
Algorithmic design lets you think beyond form — so you can focus on intent, variation, and performance. Using Marionette inside Vectorworks’ software products gives you access to a visual scripting tool built to support your vision and streamline your workflows. Explore Vectorworks today and see how algorithmic design techniques can help you design smarter, iterate faster, and create with greater freedom.
Click the button below to start a free trial of Vectorworks software.
