Learning Paths on Vectorworks University give you a free, structured, and confidence-building resource to bring Vectorworks software into the classroom, whether you’re just getting started or ready to tackle discipline-specific workflows for the architecture, landscape, and entertainment industries.
Designed for both students and professors, a Learning Path lays out clear objectives, curated courses, and step-by-step activities so you can focus less on “where do I begin?” and more on moving from core concepts to real-world workflows.
As you progress, you’ll also be more prepared for Vectorworks Certifications, turning your time on Vectorworks University into a tangible advantage for academic success and future career opportunities.
Learn more about the Academic Lighting and Academic Architecture Learning Paths below, and subscribe to the Vectorworks Newsroom at the bottom of this page to make sure you don’t miss the latest Learning Paths.
In this Learning Path, you’ll learn how to use Vectorworks Spotlight to draft a professional light plot, add accessories such as top hats, work with data and DMX, and see how lights are focused within the software. You’ll also discover how to prepare your light plot for publishing on a sheet layer and explore presentation techniques and previsualization.
This course is broken into six manageable videos, each about thirty minutes long. The six videos in this Learning Path cover the following:
You’ll learn how to organize your Vectorworks file, work with lighting symbols, and apply tools for numbering, aligning, and positioning lighting devices within your drawing.
This section covers drawing and configuring lighting pipes and booms, working with different fixture types, adding and managing accessories like gobos and top hats, using Find and Modify to update fixture attributes, and interpreting Schematic Views in relation to the 3D model.
Next, you’ll get a demonstration on using Hanging Positions with auto-numbering, applying Spotlight Numbering for both unit and DMX values, and adjusting numbering when fixtures are added or changed in your plot.
In this section, you’ll learn how to adjust fixture orientation, focus Lighting Devices, define focus points, and more.
You’ll learn how to effectively document and analyze your lighting design using Vectorworks Spotlight’s reporting and visualization tools in this section.
In the final section of this Learning Path, you’ll discover the presentation and previsualization techniques in Vectorworks Spotlight.
Be sure to log in to your Vectorworks account before accessing the free learning path.
CLICK HERE TO BEGIN THE ACADEMIC LIGHTING DESIGN LEARNING PATH.
This Learning Path explores the core elements of Vectorworks Architect and the key design processes that will guide your creative flow. Each section builds your confidence step by step, introducing flexible modeling techniques, presentation tools, and practical examples that connect design theory to real-world practice.
The Learning Path follows three main sections:
This section will help you understand the core file setup and documentation concepts, such as using 2D and 3D top views, organizing design layers and classes, working with sheet layers, and managing shared resources through library files.
In this section, you’ll learn about developing and refining your architectural models and presentation graphics. Discover how to edit Slabs with openings, control textures on individual faces, create reusable symbols from 2D and 3D geometry, precisely move objects in 3D, and configure Render settings for presentation-quality graphics.
Lastly, the tutorial at the end of this Learning Path will walk you through integrated modeling, visualization, and documentation workflows in Vectorworks Architect. With these features, you’ll learn how to create roofs from walls, use the AI Visualizer to generate conceptual images, coordinate Slabs with exterior walls, and employ viewports and sheet layer settings for clear, scalable printed output.
CLICK HERE TO BEGIN THE ACADEMIC ARCHITECTURE LEARNING PATH.
