In this blog post, you’ll learn several different ways in which you can better render and present your designs to event coordinators, producers, and numerous other potential clients.
It’s sometimes difficult to justify expending computer resources for rendering when you haven’t even won a project yet. But, at the same time, there’s nothing your potential clients will marvel at more than a stunning rendering.
So, what’s the solution? It’s simple, really: Shaded Render!
With this interactive and real-time rendering option, you can quickly create and save looks with colors, lighting, shading, and textures.
The Shaded Render mode supports glow textures, lit fog, gobos, texture bump, environmental effects, and reflections.
With the speed of the feature and the ability to make adjustments in real-time, it’s a great way for you and the people you’re selling your designs to understand what a project will look like in person.
Just as shaded renderings can be a compelling way for you to pitch design ideas to someone who doesn’t come from a technical background, you can also use textures to reduce the complexity of your 3D models.
In a traditional wireframe view, your model may be hard to read to the untrained eye. By simply applying Renderworks textures to your soft goods, scenic elements, and more, you’ll be able to improve the realism of your model and clearly communicate your design intent.
To learn more about making the most of your 3D models with renderings and textures, click the button below to watch a free webinar:
For more interactive presentations of your plans for a production, try creating walkthrough animations from your saved views.
To create saved views, perform one of the following:
Then, with the Create Walkthrough Path from Saved Views, you can create your walkthrough within the Create Walkthrough Path dialog box.
Bonus tip: Make sure your drawing Projection is set to a perspective view for use in an animation. You can use the Walkthrough or Flyover tools to change views.
One of the most effective tools you can use to present — and inevitably sell — your designs is with Vectorworks Cloud Services.
Once you’ve exported rendered panoramas to the Cloud, you can start a new presentation by creating either boards or tours using your panoramas.
Boards are flat presentations that allow you to pin different media formats to the board. Tours, on the other hand, are 360-degree walkthroughs made by linking together your panoramic images.
Tours allow your clients to feel as though they’re in your design. They’re also helpful if a client struggles to connect with plans, drawings, or still renders. Giving an immersive view of a project will allow for a greater emotional connection to (and overall understanding of) your design.
If the individual or team you’re presenting to doesn’t have access to Vectorworks, no problem! You can share presentations by direct email, QR code, or even a custom, web-based link.
For more on creating presentations with Vectorworks Cloud Services, click here.
Lastly, you may be asked to provide preliminary paperwork like worksheets specifying equipment or vendors, lighting plots, or a rough 2D mockup of your scenic elements.
You can publish all of these things and more using the Publish.
The command lets you select multiple sheet layers, saved views, and worksheets to export, both from the pitch file you’re working on or from other folders.
For each item you wish to share as part of your presentation, you can set custom options such as color.
To make custom publishing faster, save the set of publishing options that you use most frequently!
To batch publish sheet layers, saved views, or worksheets:
Be sure to check out some of our other stories on rendering with Vectorworks Spotlight:
READ | “A Rundown on Shaded Render Mode”
READ | “Event Renderings with a Bigger Impact”
READ | “Modeling, Rendering, & Reporting Models in Vectorworks Spotlight”
For more blog posts on tech tips, project highlights, and more, click here to subscribe to our blog.
