Once you’ve made good progress adopting BIM in your firm, you should be ready to use your BIM models for coordination during the design and construction process.
But with so many variables to consider, how do you know where to begin with coordinating models?
This is where a BIM Execution Plan is incredibly useful. In this blog post, you’ll find out more about BIM Execution Plans, including who’s responsible for creating them and where to get started should you need to create one for your team or help facilitate its creation with the project owner.
A BIM Execution Plan is a document written before work begins on a BIM project. The document provides details on roles, timelines, and responsibilities for all parties involved. It also covers what software, hardware, and IT infrastructure are required, plus defines who’s responsible for information management.
Essentially a coordination roadmap, the BIM Execution Plan helps ensure that all stakeholders agree how the BIM process will be carried out.
The term “BIM Execution Plan,” abbreviated “BEP,” is also known as a BIM Project Execution Plan, or BIM PxP.
Sometimes, owners and construction managers who are experienced with BIM will provide the BIM Execution Plan to the project team. If this is the case, you as an architect must review the provided plan and make sure you’re able to deliver on it. If the plan specifically requires RVT files and you’re using Vectorworks Architect, for example, you’d want to clear this up with the owner or manager and assure them that Vectorworks files can facilitate the process too through IFC or by exporting to RVT. The PIRs — project information requirements — determined by owners and construction managers are often linked to your contractual obligations, so it’s important to be on the same page.
It's also possible that an owner or construction manager wants to execute the project through BIM but doesn’t have the necessary experience to develop a BEP. If this is the case, you can use your experience and resources provided in this blog to create the BEP yourself.
If you’ve had success creating a BIM Execution Plan in the past, you can use that document as a template or starting point. If not, you can download this PDF that has standard BIM PxP requirements laid out in a template.
From there, follow this list to get started laying out the bulk of the plan.
Afterwards, make sure to perform a mockup file exchange to verify the success of the intended workflow.
If you have questions regarding the specifics of each of these points, be sure to consult our full guide to developing BIM Execution Plans.
Establishing a BIM Execution Plan before getting started on a BIM project makes workflows more efficient and successful as well as less prone to error. With deliverables and timelines clearly established for involved parties, the BEP functions as a project blueprint, making it an essential document for your BIM projects.
