November 24, 2026  |  Architecture, Entertainment, Interiors, Landscape
Download Now | Vectorworks 2027 Update 2
Alex Altieri
Vectorworks 2027 Update 2 is now available.
With support for macOS 27 Golden Gate and Revit 2027, plus improvements across modeling, file exchange, and entertainment design, this update helps you work more confidently from initial design through final deliverables.
Here’s what you can expect.
FOR EVERYONE
Update 2 makes everyday work more responsive, with faster application launches on macOS and quicker selection of complex objects such as doors and lighting devices. Creating polygons on a rotated plan is also much faster, helping you keep moving as you develop your drawings. This release adds support for macOS 27 Golden Gate, too.
Texture and workspace refinements give you more control over your working environment. A new preview object size in the Edit Texture dialog makes it easier to evaluate texture scale, while improvements to physically based rendering (PBR) textures help refine material appearance.
Need to reorganize your screen? The new Reset Palette Positions command in the Workspace menu makes it easier to reset your palette layout.
The Vectorworks MCP Server
The Vectorworks MCP (Model Context Protocol) server is offered as a public beta for subscription customers and is available on request. It lets compatible AI applications connect to Vectorworks and interact with the open file — reading project information, creating and editing objects, and running commands. The MCP server runs locally. It can be turned on and off at any time.
Customers can request access to the beta here. Once you fill out the form, you’ll be admitted to the Vectorworks MCP Server Public Beta Group. And as a member of this private group on the Vectorworks Forum, you’ll be able to share insights, tips and tricks, or seek guidance from peers and experts.
FOR ARCHITECT, LANDMARK, AND SPOTLIGHT
Collaboration and documentation improvements help keep shared projects and deliverables more predictable. Updating section viewports in Project Sharing no longer requests checkout of unrelated objects, reducing interruptions when you’re working with a team.
You’ll also find more consistent drawing output. PDF exports better preserve displayed objects, colors, and stacking order, while printed data visualizations more closely match what you see on screen. Title block text styles are retained in files from earlier versions, and drawing stamps display on top as expected.
FOR ARCHITECT AND LANDMARK
Site refinement is more consistent with improvements to Volume Fill and curbs. Volume Fill better reflects material and attribute changes, with more accurate layer-relative elevations and fill geometry. Curbs placed on curved Hardscape edges maintain their intended elevation without distorting the site model, helping you preserve the relationships between site elements as your design evolves.
FOR ARCHITECT
More reliable Door and Window Assemblies help you create and edit building models with greater confidence. Update 2 improves frame, stool, and corner geometry, along with behavior when changing classes.
Space objects deliver more dependable information for documentation, including more accurate numbering, room finish perimeters reported in the correct document units, and improved formula-based data. Refinements to roof gables, stepped walls, and wall openings also make building-model edits more predictable.
FOR LANDMARK
New irrigation capabilities give you greater flexibility when laying out and revising networks. Main pipes can now form closed loops and ring mains, with connections maintained as pipes and connected points are moved or reshaped. Loop geometry, pipe lengths, flow calculations, and connected branches are handled together, so your network stays coordinated as the layout evolves.
Additional controls make network editing easier. Select downstream connected components directly from Pipe and Valve objects, or hold Alt on Windows or Option on Mac while placing a pipe point to avoid an unintended connection. Outlet selection more reliably matches the right catalog model, even across overlapping ranges. Hydrozone irrigation methods also now include efficiency values, so each method reflects how efficiently it applies water, and hydrozone graphics preserve holes and apply the water-use class to generated paths.
Tree and planting workflows are more dependable, too. Tree survey imports bring in correct canopy dimensions, unit conversions, and elevations, while Existing Trees better retain their classes, graphics, and tags. Landscape Areas keep their plants when plant style names, IDs, or Latin names change, helping preserve accurate plans and reports.
FOR SPOTLIGHT
Update 2 improves schematic views and power planning, with schematic objects connecting at the correct position and cables displaying in front-view schematics. Power schematics now create circuits for LED wall data cables as well as power cables, supporting more complete system documentation.
Lighting workflows benefit from faster device selection and placement, along with more dependable numbering. Spotlight Numbering correctly increments absolute addresses by each device’s DMX footprint. You’ll also find improvements to Equipment Summary Key counts, MVR exchange, and Braceworks calculations.
FOR CONNECTCAD
Keep connections and equipment layouts intact as you edit. Circuits now snap to the sockets they’re connected to, equipment symbols maintain their position, and devices retain their size when equipment items are created from them.
MORE RELIABLE PROJECT EXCHANGE
Support for Revit 2027 helps you stay current with collaborators, alongside improvements to imported roofs and RFA object positioning. IFC improvements address import and export scale, data mapping, and georeferenced files.
Update 2 also refines DWG, 3DS, USD, and GIS exchange. For georeferenced workflows, Stake and GIS Stake objects can display coordinate reference system, or CRS, units, including US survey feet, helping you communicate project coordinates more accurately.
NEW ADDITIONS TO RESOURCE LIBRARIES
Expand your entertainment design resources with updated lighting libraries from Acme, American DJ, Ayrton, and Portman Lights. This release also includes EAW audio speaker updates, refreshed Layher scaffolding symbols, and new Stageline stage symbols. Customers in the Japan region will find Panasonic lighting and clamp symbols as well.
You’ll also find a fresh infusion of audio devices from D&B, including:
  • B Series subwoofers
  • CCL Series line arrays, subwoofers, and rigging
  • CCLi Series line arrays, subwoofers, and rigging
  • U Series speakers and hanging accessories
  • xS Series speakers and hanging accessories
How to Download Vectorworks 2027 Update 2
To install the update, select “Check for Updates” from the Vectorworks menu on Mac or the Help menu on Windows. Keeping your software up to date helps you take advantage of the latest performance improvements, workflow refinements, and content.
GET FULL RELEASE NOTES
Read the Tech Bulletin.
LEARN MORE
