Vectorworks 2026 Update 3 continues our commitment to steady, meaningful improvements. This time, you can expect better visuals, smoother collaboration, and more reliable documentation.
This release introduces a powerful new AI Visualizer engine, workflow enhancements for entertainment professionals using Showcase previsualization, and a new integration with our partner Speckle to support faster, multi-disciplinary collaboration. This connector is developed and maintained by Vectorworks; Speckle provides the platform and downstream ecosystem. You’ll also find expanded manufacturer content libraries and quality improvements that make everyday work more precise, predictable, and efficient.
At the center of Update 3 is a major advancement to the AI Visualizer. The new, advanced technology engine combines accurate edge interpretation with a deeper understanding of color and material, producing faithful, high-quality images that closely match your original model or prompt-based intent.
Natural-language editing has also been refined, making it easier to adjust and polish visuals through simple, intuitive commands. The result is presentation-ready imagery created faster and with less effort, reinforcing our long-term investment in AI tools that deliver real, practical value.
For architects, Update 3 introduces the Speckle Connector, a new Vectorworks plugin that enables you to publish 3D models directly to the Speckle Web Viewer and load models back into Vectorworks. This supports real-time collaboration on multi-disciplinary BIM projects, regardless of the software your partners use.
You’ll also find expanded architecture and interiors content with new table, floor, wall, and ceiling lamps from Koncept, along with architectural metal wire mesh textures from Banker Wire.
Behind the scenes, quality enhancements improve file conversion accuracy for IFC and DWG workflows, as well as the handling and rendering of doors, windows, and wall assemblies, helping ensure more dependable construction documentation.
If you’re using Vectorworks Landmark, you’ll see fine-tuning across plant image handling, landscape area display, plant styles, and Graphic Legends, along with improved performance for trees, hardscapes, and site models. These updates support more accurate representations from early concepts through final documentation.
Enhancements to data visualization and category management in the Plant Style Manager also make it easier to work with complex planting information.
New landscape content includes fiberglass in-ground pool symbols from Compass Pools, photorealistic plant symbols and data from OzBreed, and modular steel garden edging symbols from Straight Curve.
For those using Vectorworks Spotlight, the Showcase Render Style workflow has been refined with interface improvements designed to save time.
A new teapot menu in the Showcase palette and a default render style preference in the Preferences dialog make it easier to set and manage your preferred look. A new dialog, aligned with the Edit Render Styles experience elsewhere in Vectorworks, provides a more consistent and intuitive workflow so you can focus on design instead of setup.
Entertainment content updates include new audio resources from American DJ, additional LED panel product lines from ROE Visual, fabric textures from Rose Brand, and lighting device symbols from Velvet Light.
This update also delivers quality improvements across Spotlight and ConnectCAD, including better cable tool behavior, video wall handling, equipment numbering, power schematic layouts, truss workflows, accessory operations, and lighting device rendering for smoother visualization during show setup.
Vectorworks 2026 Update 3 delivers meaningful quality enhancements across the platform, from smoother file translation to more precise graphics and improved performance. Each update builds on the last, raising the standard for reliability and professional results. Keeping your software up to date ensures you benefit from these improvements and get the most out of Vectorworks as your design work evolves.
To install the update, please select "Check for Updates" from the Vectorworks menu (Mac) or Help menu (Windows).
