We’re excited to announce the release of Vectorworks 2026 Update 1, which reinforces our commitment to a continuous development cycle and provides you with enhanced performance, so you get the most value out of your software.
Here’s what you can expect.
One Click LCA is a global leader in lifecycle-assessment (LCA) tools. With this integration, you can now export BIM model quantities and data from Vectorworks directly into the One Click LCA platform to assess the whole-lifecycle carbon of your projects.
The integration can be installed via the Install Partner Products option in the Help menu and is available with Vectorworks 2025 Update 5.
You’ll notice consistent naming for DWG Hatch Classes, highlighting our continuously improving interoperability workflows.
Data Tags linked with Stake objects show consistent behavior, giving you a more reliable process.
With Update 1, you’ll notice:
Smoother object handling: Faster performance when rotating Spotlight Pipe Clamp objects and Showcase Lit Fog styles.
Improved schematic workflows: Enhanced performance for Schematic View Label Legends.
These enhancements are designed to keep your Spotlight projects running at peak performance, so you can focus on creativity without interruptions.
To install the update, please select "Check for Updates" from the Vectorworks menu (Mac) or Help menu (Windows).
